I am using a design table to run an assembly and I am running into issues with a couple of my patterns . I have some formulas in excel that are determing the number of instances that I need for the pattern but when I go to rebuild the assembly from the table the instances inside my pattern are not unsuppressing like I want them to. It will put in the correct number of parts that I need however. I am really lost on what else to do. If anybody can help I would greatly appreciate it. I have attached a picture of what my screen lookis like after I do a rebuild.
Sean,
Can't you post a picture, don't have MS-office on this machine.
I had a very similar problem recently.
Maybe you can insert another pattern with the correct number of instances after making the changes. This way the first pattern feature will suppress but not the second.
