Low Resolution avi.
Discussion created by Guest on May 16, 2006
Photoworks is what gives you the editable image size and options for anti-aliasing. If you don't have it, then screen-capture quality is about the best you're going to do. All I can suggest in that case is that you make your screen as close to 720 lines and zoom in on your model as tightly as you can.
Good luck
John
