....this is virtual modeling method. After creating the part inside assembly, if you wish you can save the part externally by using RMB on the part in the feature manager tree and select "save part(externally)". You can assign a diffrent name and can even remove the references to make it as an independent part.
Thank you everybody!
But could you please give me a detailed instruction how to convert a sketch into new part? And what for stands RMB?
Thanks again!
Hi
Go thru the attached presentation that will clear your doubts.
-Venkat.-
