Hello all,
I am currently working on a SolidWorks Clerget Rotary Engine model for my design classes. I have been making great progress until I have tried to attach the connecting rods to to the rocker arms on the top of the cylinder heads.
If I keep the cylinder barrel assembly ridgit, I can easily rotate the cylinder assembly, along with the pistons, and cam gearing and pushrods around the stationary crankshaft.
The instant I change the cylinder barrel assembly to flexible to allow movment of valves, I run into all sorts of problems. Firstly the model grinds to a halt, and mates go out of alignment. I am wondering if the large number of flexable components is causing problems, as there is a huge number of calculations to solve as the engine rotates around the crankshaft.
I have set the entire assembly to lightweight, with no change in results. I am currently running SolidWorks on a Lenovo W500 with 4GB of RAM and a T9400 processor. I have learned to SolidWorks is only using one core becasue the task manager is saying the processor is used at 50% while the engine assembly is struggling. This is the most complex project that I have ever attempted with SolidWorks. All of my other projects (with much less moving parts) worked worked well on this computer.
Is there anything that I have overlooked? Have I made several mating errors that are only making things worse, as the model rotates around the stationary crankshaft?
I have included all of the required files.
Claudio,
I believe you have some problem with the way you have defined the mates, I have downloaded the model and as soon I have some time I will look into it and see if I can fix the issue. The screen capture you post do not show the push-rods, are those included on the assembly? if not please post a complete assembly.
Your computer and video card can be to small to work with this assembly fully resolved and to do a motion simulation, howeever if the compueter do not get out of RAM it should work (slow but will work), I have a very large computer with multi CPU's and 32Gb of phisical RAM, so I will not have any computer related problems, therefore if I am able to fix the issue and have the aseembly working on my computer it should work in yours as long as it load properly without giving an OUT of RAM error.
Will post back on this as soon as I have the time to play with your assembly.
