I am in the process of detailing a complex surface. The actual machining will be done with the model geometry. I would like to create inspection points on the surface for cmm inspection and have them in a table on the drawing. How can I make these inspection points "smart" in my table so if any changes are made to the surface my inspection points will update accordingly? Thanks in advance for any suggestions.
GC,
Not sure but might work.
Constrain a points on the surface. They will need 2 more constraints; give them from the standard perpendicular planes. You may need to offset many parallel planes if needed to constarain these points.
