We are working on a large assembly for Routing. When route sub-assy created by many users and are called into top level assy(multi-user working), route sub assy fail due to failure of external references. Editing or route is also not possible. How to solve this?
Venkateswaran, your problems could be caused by multipal users adding parts to the assembly.
If your using toolbox it needs to be the same toolbox configuration on all pc's. If your using parts from your own library you'll need to "pack and go"
When dealing with assemblies we've found "pack and go" most efficient.
