the main issue is that when we manually re-order an item in a weldment cut-list, it's item number does not change.
I would think the item numbers would never change and stay on order.
See... SPR 269792
Also there's another bug that needs to be fixed BAD... and it's been around a long time. If you have the title at the bottom of the bom the item numbers don't sort correctly.
Does anyone else need these fixed?
See... SPR 269792
I have seen, and struggled, with both of these. I usually just use the column sort feature which will re-number the item numbers but then you can't drag them to where you want.
One workaround would be to create a property in the cutlist and number the bodies as you want them to appear on the drawing then sort the cutlist in the drawing by that column and then hide it. It's not easy but if it is critical then it works.
It would be nice to have these fixed as it is a pain.
Lorne
