I am redesigning some grates for the fireplace company i work for and am having issues with the weldments feature.
I can get the part to look right, but I cannot get a 'development' length, the 'cut list' will not allow me to see the single bar that simply has bends in it as a single bar, it thinks that if you have a bend you have to cut it and weld the bend.
I'm getting a bit frustrated at trying to make this work.
Any help you can provide will be appreciated.
if your sketch is "a tangent arc between two straight lines" then select all three (or more) line and select the option "Merge arc segment bodies" This will make all selections with a bend as one member with a total length.
Lorne
