I can't get simple plates used to make an angle bracket generate a cut list.
Does the cut list feature only work on structual members?
What if I want to add a tap pad to a tubing frame?
If so, you can add properties so they come up in the cut list. Under the property manager go to cut list and expand. Under that you find the item you inserted and right click. Select properties and edit. I'm not sure if you'll be able to add dims in the cut list or not but you can add the description. (This is assuming you inserted plates from another part file)
Hope this is what you were looking for!
