Michael Hubbard
Weldment Cut List - Custom Properties
Discussion created by Michael Hubbard on Oct 31, 2008
Latest reply on Oct 31, 2008 by Michael Hubbard
I'm trying to learn weldments, because we really need to start using them here, and I've hit a snag.
I've run thru the tutorial, and the only problem I have is adding custom properties (as the tutorial teaches). This is straight from the tutorial:
In the FeatureManager design tree, right-click Cut-List-Item1(8) and select Properties.
In the dialog box:
Click in Property Name and select PARTNUMBER.
Type SUB5551 for Value / Text Expression, then press Enter.
SUB5551 appears for Evaluated Value.
Add another custom property:
Click in Property Name and select DESCRIPTION.
Type Back Frame for Value / Text Expression, then press Enter.
Click OK.
In the FeatureManager design tree, right-click Cut-List-Item5(4) and select Properties.
Add the following custom properties, then click OK:
Name
Value
PARTNUMBER
G9876
DESCRIPTION
Gusset
But when I click in Property Name, nothing happens.
Or, if I click in a box in the column under Property Name, PARTNUMBER is not an option.
What am I doing wrong??
