I'm trying to create automatically generated cutting list of timber cabinets.
Each cabinet is a single part with each piece of the cabinet being a separate body.
Can I create these cutting lists from a single part or does it have to be an assembly?
I seem to remember seeing a tutorial where a cutting list folder was in the feature tree. Is this the way to go about it?
Appreciate any help.
cheers.
Are you using weldments. If yes then cut list is generated within the part file. If not then look in help/ SW tutorial for how to use/work with Weldments.
