I have attempted to use a master sketch profile in an empty part to build my model. I need this pofile at various angles about a circle so this is why I placed it in a part to be inserted multiple times. The model is a weldment part, the empty part with master sketch is a regular part.<br /><br />I use lines in the sketch to locate the inserted parts (since there are no bodies). These constraints hold in the <As Machined> configuration. When in the <As Welded> configuration upon rebuild the inserted parts do not hold their location. Upon futher rebuilds it eventually goes back to the desired position (there is a rebuild loop).<br /><br />I know that in most cases using reference geometry should be avoided in the weldment environment, so I tried putting a dummy solid in the inserted part to locate. This also did not work.<br /><br />I have attached two files, both attempts (using ref. geometry and using solid faces and edges).<br /><br />Does anyone have any insight into this problem?<br /><br />Regards,<br /><br />C. Lawrence<br />LOVAT Inc.<br />SolidWorks Office Premium 2008 SP4.0
I would get away from using the angle in your location. To do this I create a master sketch in the part (not the inserted ones) to show the angles that you want. This would be easier to edit than editting the Move/Copy Body feature. Then I would mate to the sketch or create a planes from the sketch and mate to them. I tried to test my theory with your part but I can't because the weldment part is not in the zip file.
Lorne
