Hi, I am new with SW, and this is driving me crazy.
I created a part with Weldments. It has many different profiles (tubes, c squares, etc.). I then divided the structure into sub-parts into their own Cut-Lists (in manual mode.) I have to send the drawings to the machine shop by sub-parts.
So I created a new drawing, and added a Relative View of one sub-part of the structure. Then I added a Weldment Cut List, and it shows every single item in the structure, not just the ones in the created Relative View of the sub-part... So I selected the rows that I don't need, and did a Hide/Show to remove them.
I repeated these steps for every sub-part, for a total of 5 sheets in the drawing, all with their own Weldment Cut Lists with certain rows hidden.
The big problem is that if I update the part and return to the drawing, it updates the Weldment Cut Lists AND it populates all the tables again. Meaning that ALL the rows that I deleted in all of the sheets come back, and I have to delete them manually again....
Is there any way to force Solidworks to keep the rows hidden no matter what? I can't imagine the nightmare if I have more sheets...
If you want to have each piece as it's own part with it's own cutlist then you will have to save the bodies out to a new part and then create the drawings from that new part.
The way I do it is to keep the weldment as a whole, detail the weldment and insert the master cutlist on the front page and then create details of the individual members on other sheets by using relative views. This way a guy can take the cutlist on the first sheet, cut the raw material and label it with the item number. Then if machining needs to be done they can go to the sheet showing the detail for that item (referenced from the master cutlist). This seems to be a lot more associative rather than saving out the bodies and manually doing cutlist info.
Lorne
