on 2006 8 12:05 solidair wrote:
> No but you can drag the solid bodies, you just have to redo the properties.
Which is my problem! The cut list is VERY long and I want to re-order the parts.
> hi can anyone tell me wether it is possible get the weldment custom properties
> to call up the material that you select in the feature manager.
not possible. it's assumed that all items in a weldment are of the same material. use custom property to display material property in title block or wherever you choose.
or if you must have in cut list, type in material property for each cut list item manually
Also is there a
> way to consolidate weldment cutlist items that are the same except that one has
> say a hole in it?? Weldments seems to seperate two identicle items just because
> one has a hole in it and the other one doesn not.
Right click on cut list, de-select automatic.
Ctrl+select items you want to create a cut list item for,
right click,
create cut list item
You can get the material specified in the model to appear in the cutlist but again, you have to enter the variable youself. For example, in the material field enter the following:
"SW-Material@name of your part.SLDPRT" or "SW-Material"
Or you can put in the material that may be specified in your custom properties by entering $PRP:"MATERIAL"
