Is there any way to trim 3 weldment profiles coming into a singlepoint in one operation? From the attached JPG, if I could dothis, the resulting seam between the 3 parts would be an invertedY-shape.
I've tried several combinations of trim/extend without success.
David
David
First:
Offset surface to both planes you are going to cut from, offset =0.
Second:
Insert-cut with surface-extended surface
Third:
Hide the surface you used for cutting.
