I have a weldment of a large frame and I created a few subweldments to simplify and group items in the cut list. I never created parts from the subweldments, they are still in the original part. So how do I add properties to them so that I can show them in the cut-list?
Once you have created a sub-weldment, you then need to select thesub-weldment and add a cut list (this allows you to identify yoursub-weldment in the cut list).
To detail the sub-weldment, you need to RMB on it and select'save to file' - this puts the sub-weldment into a new part whereyou can then add the cut lists to the bodies contained in thesub-weldment (note: any cut list properties are NOT transferredacross to the new part's cut list items)
If you find that you no longer want the sub-weldment detailed as aseparate part, you will need to delete the sub-weldment - this willrelease the bodies back to the main weldment, and you need tore-assign cut list items (use automatic).
I hope this answers your question.
