dear friends,
i have created one weldaments made up of diffrent plates and library parts.
i want to give plates are one material and library parts are different material.
but i couldnt make.
i can define only one material.
what is the solution to give different material in single weldament.
kindly reply me
jeyaprakash
but i couldnt make.
kindly reply me
jeyaprakash
You still can get the size, it just requires more manual work.
SA
The material in a weldment cut list is specified by the propertiesof the weldment profile that you used, or it is added manually ifyou have not set up these properties, or you are making it from nonweldment profiles (e.g. plate).
I encourage you to submit this as an ehancement request
Best Regards
I know of no way to do this using a single part weldment. It can be done using weldment assembly method where you create each part separately and bring them into an assembly. Sounds like an enhancement request to me.
SA
