Administrator
Cut list order
Discussion created by Administrator on Sep 11, 2006
Latest reply on Sep 8, 2006 by Administrator
right click on the column you want to sort by, and hit Sort - Ascending (or Descending)
on 2006 8 12:50 James Barlow wrote:
> We recently upgraded to SW2006 SP 5.0 and now we have a problem with the cut
> list order.
> I figured out how to get the parts in the order I want on the list but my
> problem is how the list is being displayed.
> I create the list with the header at the top. This shows item number, qty, and
> other properties I need. The problem I have is that the first item is listed as
> the last item on the list. In this case the first item is 21 and the last item
> shows as 1. The list is backwards.
> If I move the header to the bottom then the numbering reverses. I have item 1
> at the top and the last item is 21 followed by the header.
> I know in a BOM you can change the direction of how the item numbers are listed
> but I don't know a way to do this with a cut list. I never had this problem
> before until we went to 5.0.
> Any suggestions?
