CTChristopher Thompson19/11/2009
What is the best file export format to transfer a Cinema 4D file into a SW2009 part file as a surface or solid? So far, I can only view the STL and no import options appear to exist to convert the STL to a nurbed surface even with the ScanTo3D add-in activated.
The other file types I received (*.wrl, *.3ds, and *.obj)  from Cinema 4D are not importing despite the SW ScanTo3D literature stating SW could import the following files types:
  • Mesh Files (*.NZIP;*.NXM;*.SCN;*.3DS;*.OBJ;*.STL;*.WRL;*.PLY;*.PLY2)
  • PointCloud Files (*.XYZ;*.TXT;*.ASC;*.VDA;*.IGS;*.IBL)
The ScanTo3D add-in is actived, so that should not be an issue, and it does not seem to create a mesh prep for STL files. So far, I have not received a solution for SW technical support except to confirm the STL file could be imported into SW. Without a surface, solid, or even a prepared mesh, it is of little benefit.
This link suggests an import option exists to import an STL file as a graphics body, surface body, or solid body is available, but the option does not appear to be available in SW2009 (x64).
