Hi! If I start a new assembly and build an internal component in it with references to the assembly, and then save this assembly, I find that the context is broken. The internal part has references to the assembly BEFORE it was saved! Does anyone know how I can reattach the references when this happens? I use 2009 educational by the way.
Thanks, Daan
I just had a coworker experience this same thing last Friday. It's the first time I had seen it. But yeah, it appears to be a bug in SW2009 (we're using SP1.0). Or maybe just an oversight on SW while implementing the internal part feature.
The only fix we could come up with is to manually edit any sketches/features containing these broken external references and re-define them after the assembly has been saved.
