I've got a sheet metal part that I used closed corner, and welded corner, and then filet the welded corner. This worked great, however when I unsupress the flat pattern the filet breaks. Is this normal? Do I have an option set wrong? Is there another way to do this? I don't have to do a welded corner, but couldn't figure out how to get a continuous filet across the closed corner.
Larry
Yes, that would be normal. The weld is not there anymore in the flat pattern so your fillet can't be associated with the welded corner and it will break.
Cheers,
Anna
