I have a Quadro FX 1400 with a certified driver. I followed Wayne's sugestion and turned it off. I'll see if that speeds things up a little. I'll also read other posts.
I'll give you the quick version. If SW doesn't like your video setup, it turns on the software OGL and does its own video. To change that setting, start SW and with no documents open, look at that box. If it's grayed out with nothing open, SW doesn't like your setup. Run SW Rx to see what it tells you.
Thanks.
Mark, there are already a number of posts on this subject. Just do a search on the forum and I'm sure you'll find your answer.
WT
