Hi
I am inserting a part into a new assembly by clicking the green tick so that the part's origin will be at the assembly's origin, but the part is not going in at the correct position. I have encountered this problem several times in the past and have not found a resolution, has any one else had the same problem and if so, is there a fix.
Craig
Turn on the display of the status bar. View -> Status Bar
This is an old issue and should be fixed by now. What version and service pack of SolidWorks are you running?
