No environment = black model?
Question asked by Terry Raymond on Nov 4, 2009
Latest reply on Nov 5, 2009 by Terry Raymond
How do you use the "no environment" option?  I've got a plain white background & I don't want any frills from environment images.
When I use it with other default options, the model renders very dark or even black.
Things I've tried:
Ambient light set to 1 (no change)
Directional light brightness set to 1 (no change)
Directional light ambient set to 1 (no change)
Same with point light and spot light (no change)
Add another light (got a little brighter)
Set material ambient to 1 (no change)
Set material reflection to 0 (some surfaces changed, most still dark)
Set material reflection to 1 (some surfaces changed, most still dark)
Set material diffuse to 1 (got brighter but not enough)
Turned off shadows (outside of part is dark, inside is bright white!)
I was pro with pov ray but I cant get this to work.  Help! =)
SW2008 SP 5
With all the above settings:
yes all the lights are outside the box!
Thanks!!
