I searched the API doc and the forums and the internet for almost two hours now and I don't find an answer.
I am programming an AddIn for PDMWE and I want to read the values of a specific file.
I don't find any routine in the API where I can generate a IEdmFile7 object by an ID or without the full path of the file.
All examples in the doc need a file object in the call but how can I get that object from the things I know in the OnCmd routine aka the contents of the ppoData array?
Any help appriciated.
Regards
Alexander
I'm with you Alexander, it is frustrating -almost all of the example assume you already have the file object.
I think the reason why they are so vague is that methods for getting the file object differ depending on how the OnCmd routine was called. i.e. the parameters [ppoData] sent the OnCmd are different if the routine was called from a RMB click, from a button in a datacard or even different trigger types. Check the help file to see how the parameters are sent.
Here is a simple example of how I get the file object if called via RMB click:
First you need the vault object:
Then once you have that, you can get the file object from the ID:
Replace X with the number of file you are working with...if you have only one file selected, use 0. If you have more than one, typically you'ld cycle through with a For...Next loop.
