Yesterday one of our users’s moved their Measure Dialog Box from one screen to the other and it disappeared and would not pop up on the screen. In my experience when reporting unexplainable problems like this to the VAR they suggest send in the Rx or just renaming or deleting the registry which removes all of the user’s customizations but this engineer needs to work not spending all day fixing all the customizations they made to a newly installed version. To make a long story short I verified that renaming the users SolidWorks registry entry would fix the problem and then actually found the registry entry that set the Measure Dialog Box position on the screen and changed it so the box would pop up on the screen and the user did not have to redo all of the customization that they did not have a backup of. The entire time I was thinking of something Matt said on his blog the other day “if someone else can troubleshoot it, why can’t I?”
The point of my babbling is how can I get more documentation for the registry and the ability to get more technical information out of the Rx so I can diagnose more and solve more problems myself? So when I call the VAR I can say “this is what I found and this is where it crashes” instead of just “it’s broken”.
For times when things disappear off screen, please see my post: https://forum.solidworks.com/message/125033#125033
Or just download this program: http://www.compendiumdev.co.uk/forcedisplay/index.php
I would like to see some comprehensive documentation on SW registry settings though - or even a brief article explaining how SW registry entries are set up...
A brief article doesn't seem likely. A rough guesstimate made by exporting the SW registry tree and counting lines puts the number of registry entries related to SW at about 5500.
Jim S.
Ah yes, but is there any underlying method to the madness? Having each of the 5500 entries explained would be amazing, but a pointer in the right direction would still be a big help.
Although so far a lot of issues I've come across are "Oh, you're missing this entry" - I guess it's hard to work out what's missing if you don't know what you're meant to be looking for...
