Im trying to run an analysis on a frame constructed of beam elements suspended from a single central point, tethered at 30 degrees to the top of four corner posts by means of pad eyes. Probably a simple solution to this but I cant think of how to restrain it. Suggestions?
Cheers.
In an assembly, you could simply model the tethers as distance mates.
If you are doing a motion analysis, I would skip the distance mates and model the tethers as very stiff springs.
