In SW2010 when I'm using the triad to rotate a component in as assembly, how can I get it to snap to the closest degree? Help says to right click on the ring and select snap while dragging, which is highlighted, but it's not snapping while dragging.
Paul
I don't have it running to try, but if it's like Instant3D, you have to have the cursor over the value lines. That way you can have a non-snap and also a snap option while there.
WT
