Daniel Ferrucci-Herzberg
Beam Calculator vs SimulationXpress Results
Discussion created by Daniel Ferrucci-Herzberg on Oct 26, 2009
Latest reply on Nov 9, 2009 by Brian Lindahl
Here's an interesting issue...
I created a Beam Calculator calculation like this:
Greek Olympics Events:
Load Type: fixed at one end, uniformly loaded
Deflection calculation
Beams button > Select W16x45, click Done (This makes Moment of inertia 32.8 in^4)
Modulus of Elasticity: 30460000
Length: 144 inches
Load: 6000 lbs
Solve: Deflection = 2.24 in
Next, I tried the same calculation in SimulationXpress...
1)      Office Products > Structural Steel
2)      Select W16x45 beam (same as above), click create, done
3)      Extrude sketch to 144 inches (same as above)
4)      Apply material: Alloy Steel (Modulus of Elasticity ~30460000, same as above)
5)      Open Simulation Xpress
6)      Fix one end of beam, Apply 6000 lb load to top face
7)      Mesh and Run the study
8)      View results for displacement
9)      Note maximum displacement is only 0.132 inches, much less than beam calculator results.
First question: Why are the results so drastically different?
Second Question: Which result is correct?
