I am looking for a simple nesting program that will help us arrange our flattened sheetmetal parts on a standard material sheet. We don't do the laser cutting in house but want to provide our vendor with a full sheet layout to work from. All of the options I have found on the market include NC post processing / code generation and we don't need that at this time. Just simple nesting of flattened parts. The final output should be in dwg or dxf format but ideally the addon will work within Solidworks. We are running SW2009 SP3.
Thanks in advance for your help.
Could you not just place the Flat-pattern views on a sheet? Or are there too many?
See also http://www.google.ca/#hl=en&safe=off&q=sheet+metal+nesting+software&meta=&aq=0&oq=sheet+metal+nesting&fp=f320c4da25edf1bd
