having trouble getting a sketch to extrude and i have come to you for help. I am trying to model a leaf spring and i cant get solidworks to extrude the loops on the end. If i delete them it will extrude???Any sugestions???
Check if there is any extra sketch entity. Also while in an open sketch or edit sketch mode, click Tools > Sketch Tools > Check Sketch For Feature. This will check the sketch for errors that might prevent it from creating a feature.
not really sure what was different the second time around. The only thing i can think of is that there was interference somewhere, possibly when i added the thickness to it.
I may be self-intersecting, make sure your sketched loop doesn't intersect or touch the leaf body.
Thanks for the help peeps. Not sure exactly what the issue was. But i redrew it and it worked just fine.
Thanks agian
So that was the final workaround.
Doug, I will suggest if you ever get a problem that not getting resolved, upload the file(s) here or send to your VAR to dig out the issue.
Hey Deepak,
