Hello everyone
I'm currently looking for a macro to save individual parts from an open assembly as a parasolid by looking up the revision of the part in the part properties and adding it after the part number with an underscore(i.e 10000-000_A.x_t). We use a generic part rev convention A-Z; however with one exception, our first revision is a dash(-) and in this case we wouldn't have any revision attached to the part number(i.e. 10000-000.x_t)
So the macro would need to include this if else functionality:
If Rev = -
Do not add revision after part number
If Rev = A through Z
add _A.x_t or whatever the rev would be after the part number
For example
Part number 10000-000 with Rev - would be 10000-000.x_t
Part number 10000-000 with Rev A would be 10000-000_A.x_t
I'm not very well versed in making macros but here is how the flow would go if an assembly file is already open in SW:
- 10000-000.sldasm ~ Has parts 10000-000-01.sldprt and 10000-000-02.sldprt
- Save each part of open assembly as parasolid(x_t)
- Add underscore with revision(rev) if rev is A-Z; however if Rev = - ,do not add underscore or revision after part number
- If part has several configurations, prompt user to choose which configuration should be used for Save As
- Output to same file location as parasolid, for example Rev A, 10000-000-01_A.x_t
We currently have our revision saved in our properties as shown on the attached image.
If anyone has a macro this would be greatly appreciated!!!
Josh
