Hi all
So I have been familiarizing myself with solidworks routing for the last couple months, and I still find this addon to be very intermittent. The solid model 3D space routing is fine, but When I take my subassembly route and flatten it things go awry. The routes I am attempting are dummy routes simply 2 connectors with a wire between them. A few of the routes work fine, the block models of the connectors come into the drawing along with the labeled wires and wire lengths. However, the majority of the routes do not flatten correctly. When I flatten these routes I will get a stub of wire with no connectors labeled as 0in. (zero inches). I have found that if I go back to the subassembly and rebuild I will usually get one connector to show up, but only one. It seems to me that the schematic drawing is being created, but it is not being linked with the flattened 3D model?? Any help/tips would be greatly appreciated.
Greg
Hi Greg,
As these are very simple routes I guess you are not using a fromto list. If that is the case you will need to go into edit wires and add some wires or cables to the route. Without these flattening doesn't work reliably - or use a fromto list. It is a far more efficient way to work with electrical designs.
If you don't have fromto data you can create one manually using Excel or use the fromto wizard. Or, you can of course just use manual routing, then use edit wires to add the wire data.
I hope this helps.
Andy
