Hello guys,
Engineering stimulus package is very good idea...only if it work!!!
I used to have a student version which is just expired. I un-installed everything, clean the registry manually from all SW related stuff.
When I run the installed, Enter the Serial number, click next, nothing happen. It just stays there in the welcome step!
Any stimulating ideas will be very appreciated
-Mohamed
Seems to me that there is no way to fix this. So, I had to install a brand new vista on an old HDD i happen to have and installed the ESP on it. 32bit worked with no issue but 64bit crashed on startup when installed on vista 64bit.
Another approach i tried is to extract the files on the fresh OS and install them on the old one. This failed to work for me - but it might work for others with same problem.
I guess I can live with swapping HDs for 90 days!
-Mohamed
