on 2006 26 16:11 Richardwagenaar wrote:
> The user interface misses common sense and basic efficiency and it only
> gets worse every release. It might be easy to learn but it is terrible to
> drive once you are an experienced user.
I couldn't have phrased it any better myself.
and scrollwork in Solidworks. The tree shoud also be configurable
what to show. The tree is more an on screen database with a lot
of useless information like annotations, design binder, solid bodies
which are always visable and cause unnecessairy scrollwork.
These should be under an additional mouseclick instead of always
visable. The property managers are the worst when working with
multiple windows, you have to scroll all the time only to see your commands.
Only Solidworks has this type of Scrollwork, no other CAD system
has a userinterface that is restricted to the size of the window like
in Solidworks which causes Scrollworks and lots of unnecessairy mouseclicks.
drive once you are an experienced user. Shorcuts in the past could fix
almost everything but since the property manager you are forced to
using the mouse twice as much and Solidworks changed into Scrollworks.
