hey guys,
i have been given an edrawing from a client who has requested that we convert it into either a .dwg (autocad) or .dgn (microstation) format so he can edit it.
firstly, is this possible?
secondly, the only way i could open the edrawing in solidworks 2010 so i could save as another format was by changing the file type. once i did this and opened it in solid works, it converted the assembly into an stl graphic. then i try and save it as an .sat file so i can open it in autocad 2010 but autocad wont open is ( i was under the impression the sat format was an autocad format) because it saves it as an image file.
can anyone suggest how i might be able to convert this edrawing into either an editble file in either autocad format or microstation format?
thanks
