Can it be done?
I have an assembly level HW Hole feature that I'd like to mirror to the other side of the assembly.... but I can't seem to find the Mirror Feature tool. Componant mirroring doesn't work.
Can it be done?
Unfortunately, no...
They are through holes positioned from the inside wall of a tank saddle to the outside (so that I don't drill into the tank itself). You have to specify a direction for through holes and you can only do it one way.
To keep moving forward, I copied the hole feature to the other face and just made the points concentric to the first ones while keeping them on the new surface.
Saved a little sketching, but I would like to be able to change the size of all 8 holes (4 in each set) by editing only one feature.
Guess you can't have it all...
Could you just edit the existing HW hole feature and mirror the sketch points?
Don
