I have created some geometries(.stl) using CTscan data. I have to import them for CFD or Finite element analysis and surfaces should be very smooth. I have 2 questions:
1- How can I smooth the surfaces in Solidworks?
2- I use another software to creat geometries based on CT data. Is it possible that I import Ct data and make 3D objects directly in solidworks?
Thanks ,
Hani
hani,
Through the use of ScanTo3D which is part of SW Premium. Depending on the part type (organic or product design) you can use auto-surfacing or guided-extracted surface method respectively.
If you want to post the STL, or sample of it, I can show you.
Regards
Mark
