Hi, everybody,
Anybody, knows how can i simulated the solar radiation, if i need to draw the sun, or isn´t necessary, how can affect the part plastic inside the glass box. And to export the solid temperature os the part plastic to cosmosexpress to know the deformation?
Thanks a lot
I believe you will need Simulation or another FE package to do this. There is no need for a CFD code unless you want to account for cooling due to air flow in your box. You may be able to do this with a free FE package. Check out http://www.eng-tips.com/threadminder.cfm?pid=727 for threads on FE packages. I hope this helps.
Rob Stupplebeen
