I am an intern at the Engineering Department of a small elevator manufacturer in Holland. Now I have to make a 3D model of an Elevator with SolidWorks for a schoolproject.
This is what I got so far:
http://i2.photobucket.com/albums/y44/erik89/Lift.jpg
I got the shaft, contrabalance, cage and machine ready to simulate the movement of the elevator, but I can't really find out how to make the cables (according to European Standards, at least 4 ar required). How can I make an elevator cable that pulls up the contrabalance when the cage moves down?
I know I have to do something with sweep, but I guess I'm not doing it right, 'cause it doesn't seem to work. Anyone any suggestions?
Erik,
I suggest to use a cable with two (or more) configurations for the cage positions. The attached cable (kabel) is an example for two positions whereby the cable length is a given number in an equation.
If you need more than two positions you could use a design table to more easily generate the configurations.
