I have a valve that I mapped in Faro Cam2 in inches. When I exported it in .iges format, what should have been circles imported into SW as spline segments. When I exported it as a .step format, the diameters and distances were in inches but were multiplied like they had been converted from metric.
Anyone else have this or can you fix it.
Kerry Bullard
Kerry,
Did you know when you open the step (or IGES) file that you can go to the options button and change the import units to match your current SW template. I believe that this will alleviate your units problem.
Regards
Mark
