RYRichie Yosten14/09/2009
I'm selecting a dim and I'm being told to select a dim.  Did something change in 2009 with selecting a dim?  I'm trying to update a macro written in 2004 and I might be missing something...but for something that used to work everytime I'm going nuts when I'm getting "Please Select a Dimension" popup every time.
This is usually used on a part.  A user will select the body exposing the dims and then the user selects the dim and clicks in the cooresponding text field so that the dim name is entered.  There is another field that evals the expression to get the actual value.  Used to work like a charm...
Here's my code:
    Dim swDoc As ModelDoc2
    Dim SelMgr As Object
    Dim objSel As Object
    Dim dispDim As DisplayDimension
    Dim swDim As Dimension
    Set swDoc = swApp.ActiveDoc
    Set SelMgr = swDoc.SelectionManager
    If SelMgr.GetSelectedObjectCount <> 0 Then
        If SelMgr.GetSelectedObjectType3(1, -1) = swSelectType_e.swSelDIMENSIONS Then  'Type 2 is a dim
            'Set objSel = SelMgr.GetSelectedObject6(1, -1)
            Set dispDim = SelMgr.GetSelectedObject6(1, -1)
            Set swDim = dispDim.GetDimension2(0)
            swDoc.ClearSelection
            txtMaterialSizeLink.Value = txtMaterialSizeLink.Value & """" & objSel.FullName & """"
        Else
            MsgBox "Please select a dimension"
    Set SelMgr = Nothing
    Set swDoc = Nothing
    Set swApp = Nothing
