In the attached file, if I add a new configuration why does the plate end up thinner in the copied configuration than it was in the original configuration?
I'm using SW2008 sp4.0.
Hi Wayne,
This part is simplified from it's original version. I started out by using 'save as' to create it and then deleted all but one config. The original file had some lofts followed by shell operations. It also had a couple of cuts made with surfaces. The thinner length of the extrusion seems to be left over from one of the other configurations. It leaves a lot of doubt in the back of your mind if you can't copy a config. without something changing on you.
That's weird. Does the same for me in SW09-SP4.1.
Have you submitted an Rx to your VAR?
Can you reproduce this in a new part?
No idea - does the same thing here. How was the part created? Is this a simplified version?
WT
