I'm trying to connect a spline to a converted entity (a curve) in a 2-D sketch. I can select "equal curvature", but when I show the curvature combs, it is obviously not equal curvature.
I'm trying to apply 'equal curvature' to a boundary surface, but if I can't get the guide curves to have equal curvature, it fails.
Samuel,
I tried duplicating your problem and couldn't do it. My splines always matched the curvature of the converted arc. I tried 2, 3 and 4 point splines. If I made a spline with points very close to the end where the curvature continuity was applied and the spline curved away from the direction of the converted arc, I could end up with an inflection point very close to the end that would make it look somewhat like yours. I would have to zoom in very close to the end to see the inflection point if I had the spline handles turned on.
Jerry Steiger
Samuel,
If it is possible for you to share your file, we might be able to diagnose the problem.
Regards
Mark
