I have created some 3d brain models from MRI data and tried importing them into Solidworks but I am not very satisfied with the result because their native formats are mesh (STL or VRML) . Instead I would like to instead create a Solidworks part directly. I am making progress but it might be more work than it is worth. I am hoping some experienced users can advise me if I should even pursue this project or offer suggestions to improving my method.
My progress so far includes:
I first imported MRI jpegs into SW and traced splines around the images and then lofted them together. As you may know the brain has a very complex surface and I tried to loft detailed spline sections but SW would only allow me to create a very smooth loft instead. So now I am forced to make cuts for each sulcus. I have drawn 3d splines on the surface where the major sulci should be. I think I now need to create planes along these splines and draw closed splines to create individual lofted cuts for each sulcus but this seems like a daunting task. I did one sulcus this way and it does not look very good. It would be nice to smooth the edges of the cut.
I attached my part and a picture of what I want as a final result.
Thank you,
Baldwin
PS. When I did a search through the forum for "brain", I got a lot of references to "brain fart" but nothing related to a model of a brain.
