Why are the Reaction Forces different from the Mass Properties in the model?
I have simplified my issue with a very simple problem.
Part = a solid cylinder with A36 [default] defined [1731.767 lb]
Simulation
Material - same as part material
Force = Gravity - 386.22 in/s^2 [default]
Restraint = Fixed on Bottom face of cylinder
Mesh - very refined.
Reaction forces in y - direction = [1732.4 lb]
I know that the weight is not much different in this problem - but it is a hugh problem in my simulation analysis - I can give more details on my bigger issue - but first I need to know why these weights are different.
I guess my Gravity Needs to be [386.08848 in/s^2]. I am still having COG problems, but will explain more in my next post.
