If you are using the flat the part immediatley function you
should try this. Use the "unfold" technique and then select all
bends. The flatten all immediatley function does not take into
account what the actual flat pattern should look like in regards to
the bend relief. Just another idea, but I know it works.
Edit Feature/
Corner Options/
Untick Corner Treatment
& check the flattened part then.
Regards
Martin
SW 2006 sp 5
Win XP sp2
AMD Athlon 64 3800+
2gb Ram
Nvida Quadro 1400 71.84 driver
