Hi all,
I would like to be able to dimension using the diameter as a parameter, not the radius, is there any way to dimension it like in the attached picture? At the moment I have to divide it by two when entering the radius, which does not retain that relation unless I manually create a formula every time. I know I could draw an extra line with a mid-point relation but it seems like more work than should be required for something so simple..
There must be a better solution, any ideas?
Cheers,
Stew
Start the dimension tool
Select the LH line
Select the centreline
Move the cursor to the right of the centreline
Click to place the dimension
