Simulation using sketch patterns
Question asked by 1-L2G10G on Aug 31, 2009
Latest reply on Aug 31, 2009 by Joe Galliera
is this possible?  i'll give a brief explanation of what i'm going for here.  i work at a company that designs test fixtures for circuit boards and we are trying to run some stress analysis tests.  each board is pressed down by using push downs, which push it down in order for the test pads on the circuit board to make contact with the probes underneath.  we are trying to simulate this, but i need to be able to use sketch patterns (or some kind of pattern) to do this, as there can be literally thousands of probes per board.  any way to do this?  if more info is needed it i will gladly give it...thanks in advance
