I'm curious why you chose to model it that way rather than as a sheet metal part from the beginning. I presume because you were given the flat pattern? If you start the other way with a base flange and then edge flanges, then you could put in the welded corner as you desire.
if possible, i was hoping to show cosmetic weld for aesthetic purposes
I'm pretty sure the SW weld bead function only works with closed corners. Welding over gaps doesn't work.
You can always model one but that's a PITA.
thanks for all the timely replies, guys!!
WT
